Module Virtual Warehouse
Revision as of 15:57, 15 June 2021 by Merklin (talk | contribs) (Inital)
Module name Virtual Warehouse
Editor / Editeur Milen Karaganski - http://blacktiehost.com
Download or buy page / Page achat ou téléchargement External module - http://www.dolistore.com blacktiehost.com[1] github.com [2]
Last update date / Date mise à jour fiche / Fecha última actualización 2021-06-15
This module helps you manage your stock to show REAL quantity, when you have items in your Sales representatives.
When a record is created, the QTY set to the Sales representative is removed from the stock in Dolibarr, thus showing in product card the real stock you have in your warehouse.
Main page of the module helps you track products and their Qty you have in your sales representatives.
This is a free module, available at https://www.dolistore.com/, https://blacktiehost.com/shop/dolibarr-modules/virtual-warehouse-v1-0// and github.com [3]
Support is available at: admin@blacktiehost.com
