Module Zapier
Zapier
Numéro/ID du module
Doc développeur du module Module Zapier (developer)
This module is to manage links between Dolibarr and Zapier.
Create a Zapier developper account
At first, you need to have a Zapier developper acoount, create it here [Zapier Platform](https://developer.zapier.com/)
Compile and Deploy the "Zapier App" on Zapier platform
The Zapier App is a small package in javascript you have to deploy on Zapier so Zapier will be able to speak the language of your Dolibarr application.
Install Node.js
An easy option to get set up with Node.js is to visit [1](https://nodejs.org/en/download/) and download the official installer for your OS. If you're installing with a package manager it's even easier.
After installation, confirm that Node.js is ready to use:
node --version`
Install the Zapier CLI
Next let's install the Zapier CLI tools. The CLI will allow you to build your app, deploy it to the Zapier platform, do local testing, manage users and testers, view remote logs, collaborate with your team, and more:
cd dev/examples/zapier
npm install -g zapier-platform-cli
zapier --version
Run Zapier Login
Let's configure authentication between your dev environment and the Zapier platform. You'll use the email address and password you use to log in to the Zapier application.
zapier login
This command will set up a .zapierrc file in your home directory.
Install the Project
In zapier examples directory, run:
npm install
Deploying your App
Let's deploy it! When you're ready to try your code out on the Zapier platform use the push command. Only you will be able to see the app until you invite testers.
zapier register   (the first time, choose name for example "My Dolibarr")
zapier push
After a push, the Application, with the name you defined during the register step, is available when creating a Zap.
You will find original tutorial here : [2](https://zapier.com/developer/start/introduction)
Create a Zap
Create a ZAP that use the application you registered. For authentication, you must enter the login / pass of the account that will be used by Zapier to call APIs.
