Dolitemplate Module
Revision as of 14:51, 12 May 2021 by Elisa (talk | contribs) (Created dolitemplate page in english)
Module name dolitemplate
Editor / Editeur Eoxia - www.eoxia.com
Status / Statut / Estado
Last update date / Date mise à jour fiche / Fecha última actualización 2021-05-12
Note / Nota Vos emails transactionnels pré rédigés avec le maximum d'informations et de variables de substitutions
What is dolitemplate ?
Dolitemplate is a module that you can add to your Dolibarr. The module contains many different templates that include substitution variables in order to adapt the content of your emails depending on the subject. This module was created to help you with the writing of your emails in Dolibarr, it allows you to gain time as your emails will be prefilled with your information.
Installing from dolistore
    • Téléverser le fichier. Note: Si cela échoue, vous pouvez manuellement dézipper le fichier dans le répertoire custom via la ligne de commande: git clone https://github.com/Eoxia/dolitemplate.git
Installing from GitHub
Étape 1
Go to GitHub, then onEoxia/dolitemplate and clicon the green button Code.
Click on Download ZIP
Étape 2
Now, open your Dolibarr and go to Setup/Modules-Applications/Install an external app-module and you can upload your ZIP.
Étape 3
Now you should have the Dolitemplate module and you can activate it. (Pour cela, allez à Configuration-Modules/Applications-Modules installés)
Now that you installed your Dolitemplate, you can create for example a proposal, once it's created you should have a send email button, click on it and you can choose between the different templates available for this section.
Templates disponibles
Module produits et services
  • Mail envoi-reception fournisseurs
Module projets
  • Mail création de projet
  • Mail bilan de projet
Module commerce - Proposition commerciale
  • Mail de proposition commerciale
  • Mail de relance de proposition
  • Mail de 2 ème relance de proposition
  • Mail de clôture de proposition
Module commerce - Commandes
  • Mail envoi de commandes
  • Mail accusé de reception commandes
  • Mail facturation commandes
Module commerce - Proposition commerciale fournisseurs
  • Mail envoi de demande de prix
  • Mail relance demande de prix
  • Mail demande de prix acceptée
  • Mail clôture demande de prix
Module commerce - Commandes fournisseurs
  • Mail envoi commande fournisseur
  • Mail relance commande fournisseur
Module commerce - Factures fournisseurs
  • Mail envoi facture fournisseur
  • Mail relance facture fournisseur
Module Facturation/Paiement - Facture
  • Mail relance de facture
  • Mail 2ème relance de facture
  • Mail relance avant contentieux
  • Mail relance infos contentieux
Module ticket
  • Mail ouverture de ticket
  • Mail mise à jour de ticket
  • Mail fin de ticket
Les développements et améliorations peuvent être proposés sur le dépôt GIT Repository Eoxia : git-dolitemplate
test
