Module Knowledge Management
Revision as of 22:05, 11 May 2021 by Eldy (talk | contribs)
Numero/ID of module
Developer doc. of module Module Knowledge Management (developer)
Also called KM (Knowledge Management) or KMS (Knowledge Management System), this module allows you to manage a Knowledge Base.
