Modul FTP
Revision as of 09:30, 22 April 2021 by Udo.tamm (talk | contribs) (Created page with "<!-- BEGIN origin interlang links --> <!-- You can edit this section but do NOT remove these comments Links below will be automatically replicated on translated pages by...")
FTP
Numero/ID of module 2800
Developer doc. of module Module FTP (developer)
This module can add a FTP client browser inside Dolibarr menus.
Life cycle / Business rules
Not applicable
Examples of use cases
Not applicable
