Functions Dev
Revision as of 15:05, 1 April 2021 by Eldy (talk | contribs) (→‎GETPOST)
The following page describes some important functions used by dolibarr.
GETPOST
GETPOST() : function to retrieve the content of GET or POST variables in a more secure way. The PHP methods $_GET and $_POST should not be used.
Possible use :
Example in php:
$myField= $_POST["myField"];
becomes if the element passed in parameter is a number :
$myField= GETPOST("myField", 'int');
Possible parameters of the second argument :
Parameters
'none' for no parameter type check
'int' check that it's a numeric (integer or decimal). Warning, for an amount or a rate, you must use alpha to accept non decimal chars or thousand separators used by some countries. The data must be then converted with price2num(GETPOST('key', 'alpha'))
'intcomma' checks that it is a list of ID separated with commas ('1,8,123,99,...')
'alpha' same than 'alphanohtml' (kept for backward compatibility)
'aZ' verifies that it is a-z only
'aZ09' verifies that it is non-special characters and numbers
'array' verifies that it is an array
'san_alpha' purged string (do not use for free text)
'nohtml' verifies that there is no html code
'alphanohtml' checks that the data is a non dangerous string with no html code inside.
'restricthtml' must be used for any data entered by users to enter a html content
'custom' defined by the following filters and options with the parameters $filter and $options
For more information see the comments of the function in the file htdocs/core/lib/functions.lib.php
GETPOSTISSET()
GETPOSTISSET(variableName) allows to know if the GET or POST variable passed in parameter is defined.
Example in php:
if (isset($_POST['myField'])){...}
becomes :
if (GETPOSTISSET('myField')){...}
img_picto
img_picto() function to insert an image.
print img_picto(imagetitle,imagename);
