Functions Dev
The following page describes some important functions used by dolibarr.
GETPOST
GETPOST() : function to retrieve the content of GET or POST variables in a more secure way. The PHP methods $_GET and $_POST should not be used.
Possible use :
Example in php:
$myField= $_POST["myField"];
becomes if the element passed in parameter is a number :
$myField= GETPOST("myField", 'int');
Possible parameters of the second argument :
| Parameters | |
| 'none' | for no parameter type check |
| 'int' | check that it's a numeric (integer or decimal). Warning, for an amount or a rate, you must use alpha to accept non decimal chars or thousand separators used by some countries. The data must be then converted with price2num(GETPOST('key', 'alpha')) |
| 'intcomma' | checks that it is an integer with commas ('1,2,3,4...') |
| 'alpha' | same than 'alphanohtml' (kept for backward compatibility) |
| 'aZ' | verifies that it is a-z only |
| 'aZ09' | verifies that it is non-special characters and numbers |
| 'array' | verifies that it is an array |
| 'san_alpha' | purged string (do not use for free text) |
| 'nohtml' | verifies that there is no html code |
| 'alphanohtml' | checks that the data is a non dangerous string with no html code inside. |
| 'restricthtml' | must be used for any data entered by users to enter a html content |
| 'custom' | defined by the following filters and options with the parameters $filter and $options |
For more information see the comments of the function in the file htdocs/core/lib/functions.lib.php
GETPOSTISSET()
GETPOSTISSET(variableName) allows to know if the GET or POST variable passed in parameter is defined.
Example in php:
if (isset($_POST['myField'])){...}
becomes :
if (GETPOSTISSET('myField')){...}
img_picto
img_picto() function to insert an image.
print img_picto(imagetitle,imagename);
