Module Lyra
Revision as of 10:05, 1 April 2021 by Hadjer (talk | contribs)
Module name Lyra
Editor / Editeur Lyra Network - www.lyra.com
Prerequisites / Prérequis PHP >= 5.6
Last update date / Date mise à jour fiche / Fecha última actualización 2021-04-1
This module allows you to use Lyra payment gateway on Dolibarr. It has the following features:
  • Standard payment by credit card.
  • Automatic redirection to Dolibarr at the end of the payment.
  • Payment by embedded fields.
  • Payment in a pop-in.
  • Update invoice / orders after payment through a silence URL (Instant Payment Notification)
From the application
Manually
unzip modulefile.zip
If a previous version of the Lyra module is installed on your Dolibarr, you must uninstall it before adding. Connect to your FTP server and delete the plugin files and directories. Do not forget to backup your module settings.
Activation
In Dolibarr administration interface:
  • In the left side panel, browse to Setup > Modules/Applications.
  • Go to Modules installed section.
  • Click on Enable/Disable button corresponding to the Lyra Module entry to activate it.
Open module configuration by clicking the setup icon in the module row, and configure your store parameters and credentials from Lyra Expert Back Office.
