Functions Dev
Revision as of 11:50, 31 March 2021 by Udo.tamm (talk | contribs) (Created page with "The following page describes some important functions used by dolibarr. GETPOST GETPOST() : function to retrieve the content of GET or POST variables in a more secure way. Th...")
GETPOST() : function to retrieve the content of GET or POST variables in a more secure way. The PHP methods $_GET and $_POST should not be used.
Possible use :
Example in php:
$myField= $_POST["myField"];
becomes if the element passed in parameter is a number :
$myField= GETPOST("myField", 'int');
Possible parameters of the second argument : 'none','int','intcomma','alpha','aZ','aZ09','array','san_alpha','nohtml','alphanohtml','custom'.
   none' for no parameter type check,
   int'=check that it's a numeric (integer or decimal)
   intcomma'=checks that it is an integer with commas ('1,2,3,4...')
   alpha'=verifies that it is text and signs
   aZ'=verifies that it is a-z only
   aZ09'=verifies that it is non-special characters and numbers
   'array'=verifies that it is an array
   san_alpha'=purged string (do not use for free text)
   nohtml'=verifies that there is no html code
   alphanohtml'=checks that there is no html code
   custom'= defined by the following filters and options with the parameters $filter and $options
For more information see the comments of the function in the file htdocs/core/lib/functions.lib.php GETPOSTISSET()
GETPOSTISSET(variableName) allows to know if the GET or POST variable passed in parameter is defined.
Example in php:
if (isset($_POST['myField'])){...}
becomes :
if (GETPOSTISSET('myField')){...}
For more information see the comments of the function in the file htdocs/core/lib/functions.lib.php img_picto
img_picto() function to insert an image.
print img_picto(imagetitle,imagename);
Translated with www.DeepL.com/Translator (free version)
