Module SimpleStats
Module name | Simple Stats |
Editor / Editeur | Milen Karaganski - http://blacktiehost.com |
Download or buy page / Page achat ou téléchargement | External module - http://www.dolistore.com blacktiehost.com[1] |
Prerequisites / Prérequis |
Last update date / Date mise à jour fiche / Fecha última actualización | 2021-03-23 |
Note / Nota |
This modul has 2 functions to extend statistic already included in Dolibarr.
First, on th main page you can see a list of clients without an order for particular time (default is 30 days) with date of last invoice and the client's sales representative
On the second page, you can view products sold on particular date on for a period.
This is a paid module, available at https://www.dolistore.com/ and https://blacktiehost.com/product/simple-stats-plugin-for-dolibarr-erp-crm/
Support is available at: admin@blacktiehost.com
