Module SimpleStats
Revision as of 16:13, 23 March 2021 by Merklin (talk | contribs)
Module name Simple Stats
Editor / Editeur Milen Karaganski - http://blacktiehost.com
Download or buy page / Page achat ou téléchargement External module - http://www.dolistore.com http://blacktiehost.com
Last update date / Date mise à jour fiche / Fecha última actualización 2021-03-23
This modul has 2 functions to extend statistic already included in Dolibarr.
First, on th main page you can see a list of clients without an order for particular time (default is 30 days) with date of last invoice and the client's sales representative
On the second page, you can view products sold on particular date on for a perios.
This is a paid module, available at https://www.dolistore.com/
Support is available at: admin@blacktiehost.com
