Module SimpleStats
Module name Simple Stats
Editor / Editeur Milen Karaganski ([1]) - http://www.dolistore.com/
Dolibarr min version: 2.9.0    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2021-03-23
This modul has 2 functions to extend statistic already included in Dolibarr.
First, on th main page you can see a list of clients without an order for particular time (default is 30 days) with date of last invoice and the client's sales representative
On the second page, you can view products sold on particular date on for a perios.
This is a paid module, available at https://www.dolistore.com/
Support id available at: admin@blacktiehost.com
