Module Zapier
Zapier | |
Numéro/ID du module | |
Doc développeur du module | Module Zapier (developer) |
This module is to manage links between Dolibarr and Zapier.
CREATE A ZAPIER DEVELOPPER ACCOUNT
At first, you need to have a Zapier developper acoount, create it here [Zapier Platform](https://developer.zapier.com/)
COMPILE AND DEPLOYE THE "ZAPIER COMPONENT FOR DOLIBARR" on ZAPIER
Install Node.js
An easy option to get set up with Node.js is to visit [1](https://nodejs.org/en/download/) and download the official installer for your OS. If you're installing with a package manager it's even easier.
After installation, confirm that Node.js is ready to use:
`node --version`
Install the Zapier CLI
Next let's install the Zapier CLI tools. The CLI will allow you to build your app, deploy it to the Zapier platform, do local testing, manage users and testers, view remote logs, collaborate with your team, and more:
`cd dev/examples/zapier`
`npm install -g zapier-platform-cli` to install the CLI globally
`zapier --version` to return version of the CLI
Run Zapier Login
Let's configure authentication between your dev environment and the Zapier platform. You'll use the email address and password you use to log in to the Zapier application.
`zapier login`
This command will set up a .zapierrc file in your home directory.
Install the Project
In zapier example directory, run:
`npm install`
Deploying your App
Let's deploy it! When you're ready to try your code out on the Zapier platform use the push command. Only you will be able to see the app until you invite testers.
`zapier register` (the first time, choose name for example "Dolibarr") `zapier push`
After a push, the Application, with the name you defined during the register step, is available when creating a Zap.
You will find original tutorial here : [2](https://zapier.com/developer/start/introduction)
Create a Zap
Create a ZAP that use the application you registered. For authentication, you must enter the login / pass of account used by Zapier to call APIs.
