Module Scheduled jobs
Revision as of 16:14, 5 January 2021 by Framaurin (talk | contribs)
Scheduled Jobs
Numero/ID of module 2300
Developer doc. of module Module Scheduled Jobs (developer)
The Scheduled Jobs Module is a core Dolibarr module. It is optional and part of the System group in module list.
The main purpose of the module is to manage the scheduled jobs (alias cron or chrono table)
Setup screen
The only parameter that can be changed is the Security key used on the URL to launch cron jobs.
Below there is linked to :
External activation of the module
The module need to be externally activated each 5 minutes.
Depending on the environment where Dolibarr is running, the procedure to be followed is different.
Unix Environment
On Unix environment you should use the crontab entry to run the command line each 5 minutes
Windows Environment
On Windows, you have to create a new task in the Windows Task Scheduler.
  • General: don't forget to check "Run with maximum permissions".
  • Trigger: Choose according to the use of your PC
  • Action:
Select "Start a program". Then put in Program/Script: C:\wamp64\bin\php7.3.12\php.exe And in Add arguments: -f C:\wamp64\wwww\dolibarr\scripts\cron\cron_run_jobs.php xxxxxxxxxxxxxxxx admin
With 'xxxxxxxxxxxxxxxx' is the security key that you will find in the parameters of the scheduled jobs module, and 'admin' is the name of your session.
The path indicated may be different depending on the installation and software version. This task will execute a command in windows to execute the php, then launch the planned work in progress of dolibarr
