Module IP Phone
Revision as of 15:30, 17 November 2020 by Eldy (talk | contribs) (Removed redirect to Module IP Phone FR)
Module name IP Phonebook
Editor / Editeur DoliCloud - Teclib - www.dolicloud.com - www.teclib.com
Last update date / Date mise à jour fiche / Fecha última actualización 2020-11-17
Adds a service allowing an IP phone (Cisco, Thompson, Yearlink) to display the list of contacts present in the Dolibarr database. This allows a phone user to search for a name to find the phone directly from the IP phone screen, without entering the Dolibarr application for example.
On the configuration page dedicated to the module, complete the "Key to protect the URL" field. The link used in your phone's configuration for it to query and retrieve your contacts will then be displayed.
Enter characters on your phone, it must then interrogate Dolibarr and display the first and last names of the contacts found that match.
Developpement
