Module name | Select Bank |
Editor / Editeur | DoliCloud - www.dolicloud.com |
Prerequisites / Prérequis |
Last update date / Date mise à jour fiche / Fecha última actualización | 2020-11-17 |
Note / Nota |
Feature
Can select, when generating th invoice PDF, the bank account to suggest.
Prérequis
Dolibarr 3.5.0
Create bank accounts (module Bank must have been activated). The list of bank accounts appears on invoices into section to generate PDF for invoices.
