Module Scanner
Revision as of 15:22, 17 November 2020 by Eldy (talk | contribs)
Module name Select Bank
Last update date / Date mise à jour fiche / Fecha última actualización 2020-11-17
Feature
Add menu entry to pilot a scanner plugged to a Dolibarr server
Prérequis
  • Dolibarr 3.6.0
  • Linux server only
Just go on page to use the scanner and click on Scan button. You will get an image file ready to be downloaded once the scan is finished.
Developpement
