Module Pibarcode
Revision as of 14:54, 17 November 2020 by Eldy (talk | contribs)
Module name PiBarcode
Last update date / Date mise à jour fiche / Fecha última actualización 2020-11-17
Add a new barcode generation engine. This engine use the PHP library Pibarocde (non free).
Go on Module Barcode setup page and choose "Pibarcode" as the engine to build barcode.
To complete
