Module BitTorrent
Revision as of 14:41, 17 November 2020 by Eldy (talk | contribs)
Module name bittorrent
Last update date / Date mise à jour fiche / Fecha última actualización 2020-11-17
Add into Dolibarr, the capability to be a Bit Torrent tracker. This means you are able to serve files to the world on the Bit Torrent network with no need of external web sites or tools.
To complete
