Module Zip AutoFill France - Belgium - Switzerland
Revision as of 14:25, 17 November 2020 by Eldy (talk | contribs)
Module name Zip Auto Fill (France+Belgium+Switzerland)
Editor / Editeur NLTechno - www.dolicloud.com
Last update date / Date mise à jour fiche / Fecha última actualización 2020-11-17
Load into database all zip codes of France and Belgium. This allow autocompletion for all zip and/or towns input into dolibarr screens.
Just activate the module. If you find a couple zip/town not found, go into menu home - setup - dictionnary. You will find a dictionnary to add missing entry.
