Module PayZen
Revision as of 16:04, 27 October 2020 by Hadjer (talk | contribs) (Ajouter Informations module.)
Module name PayZen
Editor / Editeur Lyra Network - www.lyra.com
Prerequisites / Prérequis PHP >= 5.6
Last update date / Date mise à jour fiche / Fecha última actualización 2020-10-27
This module offers customers online payments via Payzen (credit / debit cards, among others).
From the application
Manually
unzip modulefile.zip
If a previous version of the PayZen module is installed on your shop, you must uninstall it before adding. Connect to your FTP server and delete the plugin files and directories. Do not forget to backup your module settings.
Activation
In Dolibarr administration interface:
  • In the left side panel, browse to Setup > Modules/Applications.
  • Go to Interfaces with external systems section.
  • Click on Enable/Disable button corresponding to the PayZen Module entry to activate it.
Open module configuration by clicking the setup icon in the module row, and configure your store parameters and credentials from Payzen Back Office.
