Module PayZen
This module offers customers online payments via Payzen (credit / debit cards, among others).
If a previous version of the PayZen module is installed on your shop, you must uninstall it before adding. Connect to your FTP server and delete the plugin files and directories. Do not forget to backup your module settings.
- Go into menu Home - Setup - Modules - Deploy an external module and submit the zip file
- Module is then available and can be activated.
Activation
In Dolibarr administration interface:
- In the left side panel, browse to Setup > Modules/Applications.
- Go to Interfaces with external systems section.
- Click on Enable/Disable button corresponding to the PayZen Module entry to activate it.
Open module configuration by clicking the `setup` icon in the module row, and configure your store parameters and credentials from Payzen Back Office.
