Draft:Discourse Implementation and Exploitation
Revision as of 08:31, 18 October 2020 by Jtraulle (talk | contribs) (Reverted edits by Eldy (talk) to last revision by Jtraulle)
Domains names
  • dolibarr-test-fr.traulle.net
  • dolibarr-test-org.traulle.net
These DN has been choosen to test the distinct vhosts but are not actually binded to public DNS.
You MUST edit your /etc/hosts local file (or similar) to point these addresses to IP 37.59.159.184
For Windows based machines, you can use https://hostsfileeditor.com/ for that purpose.
Clickable addresses
Replicated minimal VM for tests
For the implementation to go smooth, the vmprod1 environment has been replicated on a dedicated test VM.
  • Linux distro : Ubuntu 16.4.7
  • Webserver : Apache2
  • RDBMS : Mariadb
  • PHP : 5.6
PHP version
PHP version is installed from ppa:ondrej/php.
Apache2 config
Apache2 virtual hosts config dolibarr.fr.conf and dolibarr.org.conf has been copied from vmprod1 (Servername apache directive has just been modified to match names specified in #Addresses).
Enabling proxy and proxy_http modules.
Adding
<Location "/forum">
    ProxyPass "http://dolibarr-test-fr.traulle.net:8800/forum"
</Location>
Files
Files from /home/dolibarr/dolibarr.fr and /home/dolibarr/dolibarr.org has been copied to the same location on the test VM (however /home/dolibarr/dolibarr.org/httpdocs/files/stable has not been replicated on the test VM due to the weight/size of all packages).
MySQL/MariaDB Databases
Docker
Installed following the Docker docs : https://docs.docker.com/install/linux/docker-ce/ubuntu/#install-docker-engine---community-1
Tests for dolibarr.de migration
  • Retrieve test VM backup
  • Update packages (apt)
  • Upgrade db to postgres12 (data container)
  • rebuild web_only container tu upgrade to same discourse version as prod
Upgrade the web container
From : https://meta.discourse.org/t/faster-rebuilds/40341/13
cd /var/discourse
sudo git pull
Upgrade the data container
See https://meta.discourse.org/t/postgresql-12-update/151236#data-container-install
cd /var/discourse
sudo ./launcher stop web_only
sudo ./launcher stop data
sudo ./launcher rebuild data
Useful resources
