Module Web Services API REST (developer)
Revision as of 14:29, 3 September 2020 by Eldy (talk | contribs) (→‎Nginx setup)
Web services
Numero/ID of module 2610
User doc. of module Not applicable
Function
When enabling this module, you enable usage of web services provided by Dolibarr server. You can then make REST call of different web services provided by Dolibarr.
Dolibarr REST web services server
Once module webservices REST is activated, Dolibarr become also a server of REST web services. So you can send your own REST request to relative URL /api/index.php/xxx where xxx is name of the API to call.
A list of APIs on your installation can be found via the explorer.
Apache setup
There is nothing to do. If your Dolibarr is working with Apache, the REST API should also work. APIs will be served by the same virtual web server than your application.
Nginx setup
Like Apache, if your Dolibarr is working inside a NGinx virtual host, you should have nothing to do to have your API working. APIs will be served by the same virtual web server than your application.
However, NGinx default setup on a lot of distribution is often a gaz engine and you may experience troubles. If you experience suche troubles, you can try to edit your NGinx config file to match the following example. This is a simple localhost setup with a working REST API handling (tested with 9.0.1 on parabola gnu/linux).
worker_processes  1;
error_log  /var/log/nginx/error.log;
events {
    worker_connections  1024;
http {
    include       mime.types;
    default_type  application/octet-stream;
    #log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
    #                  '$status $body_bytes_sent "$http_referer" '
    #                  '"$http_user_agent" "$http_x_forwarded_for"';
    #access_log  logs/access.log  main;
    sendfile        on;
    #tcp_nopush     on;
    #keepalive_timeout  0;
    keepalive_timeout  65;
    #gzip  on;
    server {
    	listen		80;
        server_name     dolibarr.localhost; # adjust to your domain
        root    /usr/share/webapps/dolibarr/htdocs; # adjust to your path
        index   index.php;
        # from https://github.com/Dolibarr/dolibarr/issues/6163#issuecomment-391265538
        location ~ [^/]\.php(/|$) {
            fastcgi_split_path_info ^(.+?\.php)(/.*)$;
            if (!-f $document_root$fastcgi_script_name) {
                return 404;
            # Mitigate https://httpoxy.org/ vulnerabilities
            fastcgi_param HTTP_PROXY "";
            fastcgi_pass   unix:/run/php-fpm/php-fpm.sock;
            fastcgi_index  index.php;
            include        fastcgi_params;
            fastcgi_param  SCRIPT_FILENAME $document_root$fastcgi_script_name;
            # Dolibarr Rest API path support
            fastcgi_param  PATH_INFO       $fastcgi_path_info;
            fastcgi_param  PATH_TRANSLATED $document_root$fastcgi_script_name;
List of provided services
Only few services are available. Starting to Dolibarr 5.0 version, you can see full list of Dolibarr Web services provided, by calling the explorer here at address:
http://yourdolibarrurl/api/index.php/explorer.
You must first make the first call to the login api to get the API key. Then enter api key to get list of all other available API services.
For example, you can try the explorer on the demo instance at:
https://demo.dolibarr.org/api/index.php/explorer
You can then test directly from this explorer any API. This is the recommended solution to test any Dolibarr API since any API and parameters is documented here. As a result of any test, you will get the answer but also example on how to call the API from command line using curl.
To install, open the modules page and activate de API REST module. On the configuration page of the module, there's a link to an explorer. Click on it to open the API explorer.
On the top right corner, paste the <token> of the user you want to use to call the API and click the "explore" button. Note: The token of each user can be defined on the user record page.
After clicking on "Explore", you should see all the actions available with this token. If you don't have a lot of actions, it's probably because the according modules are not activated. If you want to see the invoices, you have to activate the invoice module in the configuration of Dolibarr. Same for products, third parties and so on.
On this exploration page of the API, you can do quite a lot of tests. Reading datas from Dolibarr and writing, modifying and deleting as well. Warning: Data are really modified in your database.
Use
To use the REST API, you have to call an url such as this one : http://<my_server>/api/index.php/<action>
with one of the 4 following methods : GET, POST, PUT, DELETE, replacing <action> by the action you want to use. Ex : http://<my_server>/api/index.php/invoices
There's different ways to do so. Here's a piece of code but you can also use libraries such as phphttpclient.com
// Example of function to call a REST API
function callAPI($method, $apikey, $url, $data = false)
    $curl = curl_init();
    $httpheader = ['DOLAPIKEY: '.$apikey];
    switch ($method)
        case "POST":
            curl_setopt($curl, CURLOPT_POST, 1);
            $httpheader[] = "Content-Type:application/json";
            if ($data)
                curl_setopt($curl, CURLOPT_POSTFIELDS, $data);
            break;
        case "PUT":
	    curl_setopt($curl, CURLOPT_CUSTOMREQUEST, 'PUT');
            if ($data)
            break;
        default:
            if ($data)
                $url = sprintf("%s?%s", $url, http_build_query($data));
    // Optional Authentication:
    //    curl_setopt($curl, CURLOPT_HTTPAUTH, CURLAUTH_BASIC);
    //    curl_setopt($curl, CURLOPT_USERPWD, "username:password");
    curl_setopt($curl, CURLOPT_URL, $url);
    curl_setopt($curl, CURLOPT_RETURNTRANSFER, 1);
    curl_setopt($curl, CURLOPT_HTTPHEADER, $httpheader);
    $result = curl_exec($curl);
    curl_close($curl);
    return $result;
This is just a working example. There's no error control and security was not in mind but you can use this code, modify it to suit your needs
The fonction has 4 parameters :
  • $method : string, "GET", "POST", "PUT", "DELETE"
  • $apikey : string, "your <token> generated earlier"
  • $url : string, url to call. Ex : "http://<my_server>/api/index.php/invoices"
  • $data : string, datas in json format. This parameter is not mandatory.
Accepted parameters
This is documented somewhat in the REST Explorer. Check that first. Second try and see what response you get. Third look at the source code for the given API.
Date
The ISO date format is accepted: %Y-%m-%d e.g. 2020-07-14. yymmdd is not accepted.
Examples with PHP
This is more examples, for different uses cases:
In every examples, we have:
  • $apiKey = "<my token>";
  • $apiUrl = "http://<my_server>/api/index.php/";
// Retrieve products list
	$listProduits = [];
	$produitParam = ["limit" => 10000, "sortfield" => "rowid"];
	$listProduitsResult = CallAPI("GET", $apiKey, $apiUrl."products", $produitParam);
	$listProduitsResult = json_decode($listProduitsResult, true);
	if (isset($listProduitsResult["error"]) && $listProduitsResult["error"]["code"] >= "300") {
	} else {
		foreach ($listProduitsResult as $produit) {
			$listProduits[intval($produit["id"])] = html_entity_decode($produit["ref"], ENT_QUOTES);
Comments :
  • I retrieve the 10'000 first products sorted on their ID in the base
  • html_entity_decode is necessary as single quotes are encoded
  • It's easy to use the same method (replacing products with dictionnarycountries) to retrieve the list of countries and their ID
// Create a product
	$ref = "my_product_ref_X203ZZ";
	$newProduct = [
		"ref"	=> $ref,
		"label"	=> $ref
	$newProductResult = CallAPI("POST", $apiKey, $apiUrl."products", json_encode($newProduct));
	$newProductResult = json_decode($newProductResult, true);
Comments :
  • before creating a product, it could be wise to check if it exists. Using my first example, you'll have  :
// my ref
// does it exist in my array
	$produitKey = array_search($ref, $listProduits);
	if ($produitKey) {
// yes
		$fk_product = $produitKey;
	} else {
// no
// Create the product
		$newProduct = [
			"ref"	=> $ref,
			"label"	=> $ref
		if (isset($newProductResult["error"]) && $newProductResult["error"]["code"] >= "300") {
// there's been an error
			echo "<pre>ERROR", var_dump($newProductResult), "</pre>";
			exit;
		} else {
// everything good
			$fk_product = $newProductResult;
			$listProduits[$fk_product] = $ref;
Comments :
  • I check if the ref of my product exist in the array created in the first example.
  • If it exists, I use it's key in the array as ID
  • If it doesn't exist, I create the product, then I add it to my array for next time then I use the ID created
  • I choose this method to do less API calls when I have to import 500 orders. I just need to retrieve the products list once at the beginning instead of searching Dolibarr each time.
Warning: The example below is not working properly. Creating an order and lines in one go is not supported. Instead you have to create an order first and with the returned order id add the lines using the /orders/{id}/lines endpoint.
// create an order with 2 products
// The array where there will be all the products lines of my order.
	$newCommandeLine = [];
// product 1
	$ref1 = "my_product_ref_X203ZZ";
	$prix1 = 10;
	$qtt1  = 100;
	$tva1 = 20;
	$fk_product1
// product 2
	$ref2 = "my_product_ref_B707FD";
	$prix2 = 13;
	$qtt2  = 37;
	$tva2 = 20;
	$newCommandeLine[] = [
		"desc"		=> $ref1,
		"subprice"	=> $prix1,
		"qty"		=> $qtt1,
		"tva_tx"	=> floatval($tva1),
		"fk_product"=> $fk_product1
		"desc"		=> $ref2,
		"subprice"	=> $prix2,
		"qty"		=> $qtt2,
		"tva_tx"	=> floatval($tva2),
		"fk_product"=> $fk_product2
	if (count($newCommandeLine) > 0) {
		$newCommande = [
			"socid"			=> $clientDoliId,
			"type" 			=> "0",
			"lines"			=> $newCommandeLine,
			"note_private"	=> "order created automatically with API",
		$newCommandeResult = CallAPI("POST", $apiKey, $apiUrl."orders", json_encode($newCommande));
		$newCommandeResult = json_decode($newCommandeResult, true);
Comments :
  • $clientDoliId is the ID of the customer in the Dolibarr database. Either you know it or you can search for it before
  • type => 0, This is a customer order (while 1 = supplier order)
// Validate an order
	$newCommandeValider = [
		"idwarehouse"	=> "0",
		"notrigger"		=> "0"
	$newCommandeValiderResult = CallAPI("POST", $apiKey, $apiUrl."orders/".$newCommandeResult."/validate", json_encode($newCommandeValider));
	$newCommandeValiderResult = json_decode($newCommandeValiderResult, true);
Comments :
  • in this example, on the penultimate line, we can see : $apiUrl."orders/".$newCommandeResult."/validate".
$newCommandeResult is the ID of the order created in the previous example
// search in the database if a customer exist
	$customer_name = "Acme Inc";
	$clientSearch = json_decode(CallAPI("GET", $apiKey, $apiUrl."thirdparties", array(
		"sortfield" => "t.rowid",
		"sortorder" => "ASC",
		"limit" => "1",
		"mode" => "1",
		"sqlfilters" => "(t.nom:=:'".$customer_name."')"
	), true);
Comments :
  • limit => 1 only 1 customer
  • mode => 1 we are looking for a customer, not a supplier (they are thirdparties too but with a different status)
  • sqlfilters a bit special but there are more examples on the explorer page
// customer doesn't exist. Let's create it and get it's ID
	$newClient = [
		"name" 			=> "customer company name",
		"email"			=> "customer company email",
		"client" 		=> "1",
		"code_client"	=> "-1"
	$newClientResult = CallAPI("POST", $apiKey, $apiUrl."thirdparties", json_encode($newClient));
	$newClientResult = json_decode($newClientResult, true);
	$clientDoliId = $newClientResult;
Comments :
  • client => 1 He is a customer (not a supplier)
  • code_client => -1 so the customer code will be generated automatically.
  • we get the customer ID in $clientDoliId
Develop your own service / API
Adding a new REST service is as easy than adding a file called api_mymoduleobject.class.php into the directory htdocs/mymodule/class. You take the example into htdocs/commande/class/api_orders.class.php
Note that if you use the modulebuilder tool, the file may be generated for you.
The framework detects automatically the API and it should be visible into the explorer.
Method and parameters are detected according to introspection done into PHP class of the object (htdocs/mymodule/class/object.class.php) using the annotations found into the class. For a documentation about annotation: https://github.com/Luracast/Restler/blob/master/ANNOTATIONS.md
These are just the basics.
Some more informations in the Dolibarr code. You can look here : htdocs/<directory>/class/api_xxx_class.php
Ex : htdocs/societe/class/api_thirdparties.class.php for thirdparties.
Ex : Invoices are in htdocs/compta/facture/class
