Module DAV
Revision as of 14:11, 3 September 2020 by Eldy (talk | contribs) (Created page with "<!-- BEGIN origin interlang links --> <!-- You can edit this section but do NOT remove these comments Links below will be automatically replicated on translated pages by...")
DAV
Numero/ID of module
Developer doc. of module Module DAV (developer)
The DAV module add a server component to offer a shared public (no login required) and/or a private directory (need to use a Dolibarr login) that you can access with any WebDAV client. The content of the manuel directory of the Module ECM can also be accessed (nedd to use a Dolibarr login).
For the section that are protected by a login, Dolibarr use a HTTP Basic authentication. So if you already protected your Dolibarr directory with a HTTP Basic authantication protection, you must exclude the path */dav* from this protection to avoid a duplicate HTTP Basic authantication that will conflict.
Just go on setup page to get the WebDAV repository that is enabled and available with WebDAV protocol. Use any WebDAV client to access this repository.
