Module Categories
Categories | |
Numero/ID of module | 1780 |
Developer doc. of module | Module Categories (developer) |
The module category allows you to manage categories for third parties (customers or suppliers) and for products.
If a cog icon appears on module thumb or at end of the line of the module, click on it to access the setup page specific to the module.This module can be viewed under “Multi-modules tools àTags/Categories”.
Example of use case
UCCA01: | |
Situation | |
Actions |
