Module Purchase Orders
Suppliers | |
Numero/ID of module | 40 |
Developer doc. of module | Module Supplier (developer) |
The module Purchase Orders, also called Supplier Order is currently hosted by the module *Supplier*. You can type in orders you make to your customers, with lines of details, send them to him and received products in stock if you use the Module Stocks En.
Life cycle / Business rules
A supplier order follows the following life cycle:
Draft (0) --> Validated (1) --> Approved (2) --> Process running (3) --------------------------------/---> Received completely (5) \ \ \--> Received partially (4) ---/ \ \ \ \--> Canceled (7) \ \ \ \ \ \ \-----------------------\-----------------------------------------\----> Creation of invoice (if module invoice on) or "Classify billed" \ \ \ \- Canceled (6) \ \- Refused (9)
Create a supplier order
The creation of a supplier order is done from the supplier file in the third party or suppliers section of the application, supplier tab. The button allowing it is found in the action bar of the supplier file.
The order is then created in the draft state.
You must then select products sold by the supplier from the given list. If you want to add a new product, it is necessary to go through the interface of the products / services, to create a product then to use the supplier tab of the product sheet and to indicate the minimum price and quantity for this supplier. The product is then available in the list of products from this supplier and can be added to the order line.
Close a supplier order
Once the products or services of an order have been received, you must return to the order form to enter the receipt. The status of the order then passes to partially received or completely received depending on the information entered.
Delete a supplier order
To delete an order, you need to open its file. An order can only be deleted if it is in draft form. Once validated, it can only be canceled. The deletion of an order erases all the data relating to it.
A deleted order cannot be recovered.
Modify a supplier order
To modify an order, you must open its file. An order can only be modified if it is in draft form.
Use cases
UCSOR01: Supplier Order | |
Situation | |
Actions |
