Setup Widgets
Revision as of 09:00, 8 June 2020 by Framaurin (talk | contribs)
Help About Screen: Widgets Setup
Menu Path: Home ► Setup ► Widgets
Widgets Setup
Widgets Setup
Widgets are components showing some information that you can add to personalize some pages. You can choose between showing the widget or not by selecting target page and clicking 'Activate', or by clicking the trashcan to disable it. Only elements from enabled modules are shown.
Widgets available
List of widgets that are available but not activated.
Widgets activated
List of widgets that are activated. You can choose the order or to disable them.
