Module Dolimport fr
Module name DOLIMPORT API
Last update date / Date mise à jour fiche / Fecha última actualización 2020-05-27
Import your bank statements from a csv file or connect directly the information from your QONTO bank account. Then many options are available :
  1. Create and paye a customer invoice
  2. Create and paye a vendor invoice
  3. Create and pay a VAT
  4. Create and pay a salary
  5. Create and pay a social and fiscal taxes
  6. Pay an existing customer invoice
  7. Pay an existing vendor invoice
  8. Pay a loan
  9. Pay an expense report
  10. Link a payment to a transaction
If you use QONTO API, you can download the attached files of QONTO directly from Dolibarr. Also the VAT and all other usefull information will be used to generate the Dolibarr elements.
If the reconciliation option of the bank account is activated in Dolibarr, Dolimport API will also automaticaly reconciliate the statement.
Module Configuration
Module setup page
Configure the module from the module setup page, you can define :
  • The default project you want to link the element (this value can be change later in the form)
  • The default VAT value (this value can be change later in the form or directly define in the CSV file or in QONTO)
  • An option to show only open project in dolimport API form or all projects
  • An option to add a unique number for vendor reference (avoid double reference)
  • The period of time you want to show in the list of transaction
Connect to QONTO API
If you want to use the module with a csv file, you have nothing more to do.
To connect Qonto to Dolibarr, go to the bank account card in Dolibarr.
Dolimport API automatically add 3 fields : ID API, KEY API and BANK API.
Extrafield BANK API setup
Select QONTO as BANK API value (for now it is the only option).
Extrafield ID API & KEY API setup
Go to your QONTO account : | QONTO
On the left menu of the QONTO web page, select "paramètres."
On the left menu select "intégration API".
Now you can go back to Dolibarr and fill the ID and KEY API with the info found on the QONTO website.
Menu
You can see this module in the left menu of the "bank" top menu.
If you choose the QONTO API option, only one link will appear in the menu, this is the list of transactions.
If you are not using QONTO API (so you are using CSV import), 2 links will appears in the menu, one to import transaction from a csv file and an other to see and process the transactions.
Import a file (only if you use CSV files)
Go to the page : "load a csv file".
The left section of this page allows to prepare the import of the CSV file. All the parameters are saved for the next import.
  1. Select the date format as it is on the csv file
  2. Select how the amount (credit and debit) are shown in the csv file
  3. Select how the payment is defined in the csv file, if the payment mode is define so we need the translation between the Dolibarr payment mode and your bank statement csv file. The files below "translation" allow to explain how the payment mode are named in the csv file.
The right section of this page show the csv statement already importes. You can delete the statement doing click on the trash bin icon.
Setting of the lines
Once your csv file is uploaded, select the category of each column (date of operation, date of value, amount, label, secondary label).
The fields operation date, label and amount are required, the other fields are optionnals.
Uncheck the lines that you do not want to import (for example if there is a title line).
Before to import give a name to the bank statement, it will help to reconcile.
Sometime PHP limits the quantity of datas you can import, if a message shows that there is too much columns and rows, you should delete columns in the csv file or divide the csv file in many files.
Generate Dolibarr elements from the list of transaction
If you already successfully load a csv file or if your QONTO bank account is connected to Dolibarr, you can see the list of the transaction doing click on the name of the bank account in the menu.
Generate the elements (invoices, taxes, salaries,loan...)
To generate a Dolibarr element (invoice, expense report, payment, loan...) you have to make a click on an icon on the right of the click.
Select the icon depending of the type of element you want to generate.
