Module ECommerce NG (Magento)
<seo metak="Magento, Dolibarr, synchro, synch, interface" />
| Module name | Ecommerce NG (Magento) |
| Editor / Editeur | Teclib - www.teclib.com |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2020-05-22 |
| Note / Nota |
Integrates a synchronization between Dolibarr and an eCommerce platform. Support for Magento is stable and experimental for WooCommerce. Support for Prestashop is still in development (contributions are welcome).
It is a module to be installed in Dolibarr. Access to the eCommerce platform is done by Dolibarr using default WebServices provided by the eCommerce solution.
NOTE: This module is using the same core as Module ECommerce NG (Woocommerce) EN.
Magento
We suppose you have a Magento already available. If not, this is quick steps to install it:
- Go on www.magento.com to download last version.
- Unzip package on a magento root directory
- Create an empty database on your mysql/mariadb server
- Create a virtual host on your apache server to point to this magento directory and call this url. Use external url for your localhost. A wizard will start to initialize Magento. Note: If you need to work locally only, with an internal URL, you must known than with magento < 2, the name of the virtual host can't be "localhost". But you can edit your /etc/hosts file to add an entry like magento.local or localhost.localdomain on ip 127.0.0.1 and use this (this suppose you want to work locally only).
Note 1: The URL for administration backoffice may be /index.php/admin or /index.php/administrator or /index.php/admin_xxxxx (where xxxxx is a number)
Note 2: To reset password of an admin user: UPDATE admin_user SET password = MD5('NEWPASSWORD') WHERE username = 'admin';
Note 3: config files of Magento are stored into app/etc
Dolibarr module
From the application
Manually
unzip modulefile.zip
Setup on Magento side
- Create first a Webservice SOAP/XML RPC role from admin interface System - Webservices - SOAP/XML RPC Roles, for example role soaprole. Grant this role Access to *All resources*.
- Create a Webservice SOAP/XML RPC account from admin interface System - Webservices - SOAP/XML RPC User, for example account soapuser. Remember the password you used into field API key during user creation. Set this user to the role you created at previous step. Note: A user with no role set is useless and Dolibarr won't be able to login with it.
- The parameter System - Configuration - Services - Magento Core API - WS/I Compliant can be set to true or false.
- Note: If you create a product, to have it visible on Magento shop, check that qty in stock is higher than zero, that status "Stock Availability" is set to "In stock" and that product is inside a category of the site.
- Note: With Magento, the stock of a product decrease on Magento side as soon as an order is done on Magento shop.
Setup on Dolibarr side
- Saisir l'URL des services SOAP Magento.
- Renseigner le login et l'API key créé à l'étape précédente dans Magento (soapuser).
- Choisir la catégorie à utiliser pour marquer les tiers issus de Magento ou ceux à pousser sur Magento. Le tiers assigné à cette catégorie seront poussés en temps réel sur Magento.
- Choisir la catégorie mère dans laquelle sera créée les catégories produits issues de Magento. Les produits créés ou modifiés qui sont assignés à une catégorie ou sous-catégorie de cette dernière seront poussés sur Magento en temps réel.
- Stock synchronisation direction: Option Stock synchronisation direction: Mettre le sens de la synchronisation du stock.
- Warehouse for stock initialization: Enter here the warehouse that will be used for any stock init/change when a product is created into Dolibarr because a new product (with a stock not empty) is found on eCommerce shop. This parameter is not used if previous option Stock synchronisation direction is set to None or dolibarr2ecommerce.
Synchronize from Magento to Dolibarr
Before doing your first synchronization, you must check this:
- Be sure to not having too much categories on Magento side (< 1000)
- If you already have thirdparties on Dolibarr side, check that reference of thirdparties are same than name on your ecommerce. If not, the synch won't be able to detect a record already exists and it will recreate another thirdparty on Dolibarr side. For contact/addresses, check is done on all fields "firstname + lastname + address + zip + town".
| Action into Magento | Effect into Dolibarr | When | Note |
| Categories created/modified into Magento | Created into Dolibarr as sub-categories of the parent category used for Mangeto categories (defined into module setup) | Manual click on "Magento to Dolibarr sync" button | Available Table llx_ecommerce_category is updated to store a link between dolibarr category id and remote magento id. Due to a lack of search on last modified time on Magento API, this sync may be slow if you have a high number of categories
| Products or Stock created/modified into Magento | Created into Dolibarr and linked to its categories. If module stock is enabled and Stock synchronisation direction was set to "ecommerce2dolibarr", stock is also initialised/updated into warehouse defined into eCommerce dolibarr module setup |
Manual click on "Magento to Dolibarr sync" button | Available Table llx_ecommerce_product is updated to store a link between dolibarr product id and remote magento id
| Thirdparties and contact/addresses created/modified into Magento | Created into Dolibarr | Manual click on "Magento to Dolibarr sync" button | Available Table llx_ecommerce_societe and llx_ecommerce_socpeople is updated to store a link between dolibarr thirdparty id and remote magento id. To know if a thirdparty already exists, Magento check on the ref. To know if a contact already exists, Magento check on all fields firstname, lastname, address, zip, town (and thirdparty).
| Orders created/modified into Magento | Created into Dolibarr | Manual click on "Magento to Dolibarr sync" button | Available Table llx_ecommerce_commande is updated to store link of dolibarr order id and remote magento id
| Shipment created/modified in Magento | Creating a shipment in Magento is changing Magento status of the Order from "pending" to "processing". Because it is changing status of order, see case "Order created/modified into Magento". | Manual click on "Magento to Dolibarr sync" button | Available Note: The shipment is not downloaded into Dolibarr, only status of Dolibarr Order will be changed like is the Magento order.Note: You may choose to manage shipment on Dolibarr or Magento (we recommand to create/update shipments on Dolibarr and not into Magento). |
| Invoices created/modified into Magento | Created into Dolibarr (with correct status but without payments) | Manual click on "Magento to Dolibarr sync" button | Available Table llx_ecommerce_facture is updated to store a link between dolibarr invoice id and remote magento id.
In recent version of module, the "Magento to Dolibarr sync" button can be completed with a scheduled job/script that can launch the synch automaticaly every hour for example.
Synchronize from Dolibarr to Magento
| Action into Dolibarr | Effect into Magento | When | Note |
| Categories created into Dolibarr | No update is currently done on Magento. In a future version, creation will be done into Magento if category is inside the parent category for Magento, defined into module setup | No creation/update is currently done on Magento. In a future version, sync will be in real time | TODO
| Categories modified into Dolibarr | No update is currently done on Magento. In a future version, update will be done into Magento if category is linked to Magento (category was created by a "Magento to Dolibarr sync") | No creation/update is currently done on Magento. In a future version, sync will be in real time | TODO
| Products created into Dolibarr | None. In a future, creation will be done into Magento if product has a category inside tree of Magento categories | No creation is currently done on Magento. In a future version, sync will be in real time | TODO
| Products or Stock modified into Dolibarr | Update into Magento is done if product is linked to Magento (product was created by a "Magento to Dolibarr sync") If module stock is enabled and Stock synchronisation direction was set to "dolibarr2ecommerce", then stock is also overwritten on Magento |
Real time | Available
| Thirdparties created | None. In a future version, creation will be done into Magento if thirdparty has the category of Magento thirdparties (defined into setup) | No creation is currently done on Magento. In a future version, sync will be in real time | TODO
| Thirdparties modified into Dolibarr | Update into Magento is done if thirdparty is linked to Magento (thirdparty was created by a "Magento to Dolibarr sync") | Real time | Available
| Contact/addresses created into Dolibarr | None. In a future version, creation will be done into Magento if thirdparty has the category of Magento thirdparties (defined into setup) | No creation is currently done on Magento. In a future version, sync will be in real time | TODO
| Contact/addresses modified into Dolibarr | Update into Magento is done if contact/address is linked to Magento (contact/address was created by a "Magento to Dolibarr sync") | Real time | Available
| Orders created (validated) into Dolibarr | None | Orders created directly into backoffice does not need to appear into ecommerce. See next line for Orders modified. | |
| Orders modified into Dolibarr | Order will be updated into Magento if order is linked to Magento (order was created by a "Magento to Dolibarr sync") | No update is currently done on Magento. In a future version, sync will be in real time | TODO
| Shipments created (validated) into Dolibarr | Shipment will be created/modified into Magento if source order of shipment was created by a "Magento to Dolibarr sync" | Real time | Available
| Shipments modified (closed) into Dolibarr | This step does not exists on Mangento, so nothing is done | NA | |
| Invoice created (validated) into Dolibarr | None. In a future, invoice will be created/modified into Magento if source order was coming from Magento | No creation/update is currently done on Magento. In a future version, sync will be in real time | TODO
| Invoice modified into Dolibarr (for exemple when status change to paid because of a payment entered) | None. In a future, invoice will be created/modified into Magento if source order was coming from Magento | No creation/update is currently done on Magento. In a future version, sync will be in real time | TODO Priority 1
| Stock of a product modified into Dolibarr (whatever is reason: shipment processed, order or invoice validated, depending on your Dolibarr setup of the stock change rule, manuel change of stock or inventory) | Stock is updated on Magento if product exists also in Magento and if synch direction was set to "Dolibarr2Ecommerce" | Real time | Available
Please submit your PR to this repository if you make enhancements to this module.
TroubleShooting
Due to a problem in Magento, if you have a large number of product categories, you may experience low performance when counting data to synchronize and when making a synchronize. This is how you can fix this:
On Magento 1.9 side, edit the file app/code/core/Mage/Catalog/Model/Category/Api.php to add the line that is under the comment /* FIX */
* Convert node to array
* @return array
// Only basic category data
$result = array();
$result['parent_id'] = $node->getParentId();
$result['name'] = $node->getName();
$result['is_active'] = $node->getIsActive();
$result['position'] = $node->getPosition();
$result['level'] = $node->getLevel();
$result['updated_at'] = $node->getUpdatedAt();
$result['children'] = array();
return $result;
