Module CustomizeForms
Module name | CustomizeForms |
Editor / Editeur | paulorcdo - https://www.trucolivre.com.br/dolibarr/ |
Download or buy page / Page achat ou téléchargement | External module - On [1] |
Prerequisites / Prérequis |
Last update date / Date mise à jour fiche / Fecha última actualización | 2020-05-18 |
Note / Nota | Module CustomizeForms |
Logo
Customize Forms allows you to create new features in 24 dolibarr create and edit forms ( + 430 standard fields and + all extra fields)
1- Hide fields;
2- Make fields as mandatory (Javascript);
3- Disable fields;
4- Create Custom Header and Footer;
5- Define default values for fields (texts, lists, html, selection and categories);
6- Create tooltip with instructions on the fields;
7- Create auxiliary lists of preformatted texts and phrases to easily insert into the fields (text, html);
8- Change the presented names of the fields without changing the translations;
2- The module is installed in the Tools menu of Dolibarr, click on the menu and on the left will appear the link Customize Forms.
3- Click on the Customize Forms link and you will be taken to the system home page.
Permissions:
1- Initial system permissions are set with access only to the System Administrator;
2- For new users, the administrator can configure read, edit, and delete permissions on the Dolibarr user or group permissions tab.
Pages
Page 1 - Home Page - List Forms
- The Home Page lists all 24 Dolibarr forms that can be configured by Customizeforms.
- The Qty column tells you how many fields can be set on each form.
- To Customize a Form, just click the pencil on the right form.
Page 2 - List All Form Fields to Customize
- In this example, we click on the Home Page in the New Commercial Proposal - Customer form.
- This page only displays fields with default values that have already been set. All fields of the form are displayed on this page.
1 - Extrafields that were created for this module will be inserted automatically when you open the page.
2 - The Header and footer fields are options that can be added to the form.
- Name: Field Name
- Situation: Current field status - Can be Visible, Invisible, Disabled, or Required.
- Default Value: Value set to appear as default for the field (text fields, checkbox, selects, textarea).
- Tag: New Name Defined for Field
- Auxiliary List: List of Text separated by line breaks that can be added in any text field or textarea.
- Help Text: Help text that appears when you approach the mouse.
Page 3 - Customizing a form field
In this example, we click in the New Commercial Proposal - Customer form (Page 1) and after we click on the Customer field (Page 2).
To apply module functionality to the form example:
- To Hide fields:
- Click in the combo box Define Visibility and Mandatory and select Invisible option (The entire line will be invisible);
- To Make fields as mandatory (Javascript):
- Click in the combo box Define Visibility and Mandatory and select Required option;
- To Disable field:
- Click in the combo box Define Visibility and Mandatory and select Disable option;
- To Define default values for field (texts, lists, html, selection and categories):
- Click in the combo box Set Default Value and select the desired option (Dolibarr options to combo box and checkbox, other field type only write the text to default value);
- To Change the presented name of the field without changing the translations:
- Digit new name text to Modify Field Name;
- To Create auxiliary lists of preformatted texts and phrases to easily insert into the fields (text, html):
- Digit List of Text separated by line breaks that can be added in any text field or textarea in Create Auxiliary List to insert into text or HTML fields;
- To Create tooltip with instructions on the fields:
- Digit html text to Create Tooltip with Help Info;
- To put the current date in the date fields (fields that have the dolibarr link):
- Click in the combo box Set Default Value and write the text now() to default value;
1- Choose the form on the home page of the module (Page 1);
2- In the chosen form, click in the Header or Footer field (Page 2);
3- In Page 3:
- Click in the combo box Define Visibility and Mandatory and select Visible option;
- Digit new name text to Modify Field Name, this field is a name of Header/Footer in the left table form;
- Digit html text in the field Set Default Value , this field is a content of Header/Footer in the right table form;
Prerequisites
Partial Features - Dolibarr ≥ 5.0.3
All Features - Dolibarr ≥ 9.0.3
Demo
View DEMO:https://www.trucolivre.com.br/dolibarr/ user:demo passw:demo
Buy
On https://www.dolistore.com/en/modules/1133-Customize-Forms.html
Video
View Video: https://www.youtube.com/watch?v=wTR9DMnpIck
