Help about screen: EMail setup
Menu path: Home -> Setup -> EMails
The EMails setup screen allows you to setup Dolibarr to send EMails and to test your setup.
E-Mails setup parameters
This is explanation of all setup parameters:
Disable globally all emails sendings (test mode or demo)
Set this to No. If you set to yes (for a demo system for example), no more mail will be sent.
Method to send emails
  • The default method is PHP mail function. This means that Dolibarr use your PHP to send emails. This suppose your PHP setup is complete. If you don't know how to setup PHP for email sending, prefer next method.
  • If your email sending server needs authentication, or if you don't have permission or knowledge to setup your PHP, choose the second method: SMTP/SMTPS socket library (or Swift Mailer socket library if you fails to make the previous one working with your email provider).
  WARNING
Some email provider (like Yahoo) does not allow you to send an email from another server than the Yahoo server if the email address used as a sender is a Yahoo email (for example myemail@yahoo.com, myemail@yahoo.fr, ...). If you sue the PHPmail method, it means you will use the server of your application to send emails, so some recipients (the one compatible with DMARC protocol), will ask Yahoo if they can accept your email and Yahoo will respond "no" because the server is not a Yahoo server, and some of your Emails may not be received.
If like Yahoo, your Email provider has this restriction, you must set this setup to choose the other method "SMTP/SMTPS socket library" and enter here the SMTP server and credentials provided by your Email provider.
Hostname or ip address of SMTP/SMTPS sending server
Name or IP address of the server that send mail. It is usually an name like smtp.xxx.zzz provided by your Internet Service Provider.
For example:
  • smtp.aol.com
  • smtp.free.fr
  • smtp.myprovider.com
  • smtp.gmail.com (with login/pass of gmail or gmail for works account)
  • smtp-relay.gmail.com (with mode relay of gmail for works)
Port of SMTP/SMTPS sending server
If the email sending server use the standard port (25), you can let the field empty.
Other examples:
  • 25 (SMTP standard)
  • 465 (SMTPS gmail of free Gmail or Gmail Suite)
  • 25, 465 or 587 (SMTP gmail with the mode relay available with Gmail Suite, depending on setup)
SMTP Authentification ID
Visible if you have choose SMTP/SMTPS socket library as sending method. Put here your login.
Visible if you have choose SMTP/SMTPS socket library as sending method. Put here your password.
Usage of TLS (SSL)
Some emails servers require encrypted communication (For example the SMTP server of Google smtp.gmail.com. It's SMTPS).
The only method that support this protocol is SMTP/SMTPS socket library. You must enable cryptography by setting this method if you need such encryption.
Note: SSL functions must be available in your PHP. If not, you probably forget to install the openssl module of PHP.
Note: There is 2 different types of SMTP secured encoding:
  • Sending SMTP protocol inside a crypted stream (SSL or non standard TLS). Server is often running on port 465.
  • Sending crypted data inside SMTP (TLS using STARTTLS). Server is often running on port 587.
Dolibarr option can manage the first case, the second one is supported started to 4.0+.
More information on difference between TLS and STARTTLS here: https://www.fastmail.com/help/technical/ssltlsstarttls.html
EMail used as sender for automatic emails
Set here the eMail that will be used by Dolibarr as emails sender, if sender is not explicitly defined.
Examples for common Mail server setup
This is some examples of values (for common email providers) to use to setup your emails with your email provider. Contact your email provider if it is not in this list or if you are not sure of which value to use to ask him the credentials (SMTP server, port, Use of TLS or not) to use their SMTP server.
Gmail (with login/pass)
  • SMTP server: smtp.gmail.com
  • Port: 465
  • SMTP Username: Your Gmail login (xxx@gmail.com or xxx@yourdomain.com)
  • SMTP Password: Your Gmail password (or the alternative application password, see later)
  • Use TLS (SSL) encrypt: yes
  • Use TLS (STARTTLS) encrypt: no
  Because using this smtps access need to store your login/pass into application, this access is classified by Google as a "less secured access". So check that such access is enabled for your Google account: Take a look at your dashboard for parameter: "Access for less secured application" on http://www.google.com/settings/security/lesssecureapps.
If the 2-steps authentication is enabled, this parameter is always disabled. In such a case, you must create a dedicated second password for your account. This can be done on: https://myaccount.google.com/security, menu "Application password". Create a dedicated password. You must then use it instead of your standard Gmail password into setup (the login does not change).
Also note that Google will probably close the feature to use the "less secured access" in february 2021. You would have to use the next method if you are a Gmail user (Gmail with relay server).
  If you have email aliases on your account, be sure to set here the main username and not the alias.
  Note also that when sending email with google smtps, if the email of sender is not the google email, neither a declared alias, google will replace the "From" visible by the recipient with your default email alias (but the reply to will still be the sender email even if not declared)
Note: With this mode, emails sent are automatically added into "Sent" folder of the main account. If your are a Gsuite user with several users/mailboxes, prefer to use the next method.
Gmail (with mode relay of Gmail with GSuite)
  • SMTP server: smtp-relay.gmail.com
  • Port: 25, 465 or 587
  • Use TLS: Depend on relay setup
  • Login/Pass: Keep login/pass empty (Choice A). In such case, you must set "Allow some IP addresses only" and enter the public IP of your Dolibarr server. Or (choice B) enter your GSuite email account and a "application" password that is not the password of your account but a second password generated from https://myaccount.google.com/security).
Note 1: You must first setup your Google account to relay outgoing email and to set the list of ip of your SMTP clients (https://admin.google.com, Application - GSuite - GMail - Advanced setup - Routing). Choose "Accept all emails from my domain" or "Accept all", Choose "Enable TLS" and choose "SMTP authentication required" to no (Choice A) or yes (Choice B).
  • If you made Choice A, you must also enter the public ip address of the server of your Dolibarr in "Allow some IP addresses only".
  • If you made Choice B, you must create an "application password" from https://myaccount.google.com/security and use this one.
Whatever is the choice (A or B), you will never have to enter the password of your Google account when using the GMail relay solution.
Note 2: With this mode, emails sent can also be saved into the "Sent" folder if option "Stock a copy of all emails sent..." is on.
If your are a Gsuite user with several users/mailboxes, this mode is required if you want to have each user having its sent mails automatically stored into its own "Sent" directory of Gmail.
iCloud
iCloud does not support SSL/TLS, only TLS with STARTTLS, so you must use Dolibarr 4.0+ to use it.
Setup would be:
  • Server: smtp.mail.me.com
  • User name: Your iCloud Mail email address (Do include the domain name—what follows "@" in your iCloud Mail address; if your iCloud Mail email address is "me@icloud.com", for instance, do use "me@icloud.com" as the user name.)
  • Password: iCloud Mail SMTP password: Your iCloud Mail password or an app-specific password (with two-step authentication enabled)
  • Port: 587
  • Use TLS (SSL) encrypt: no
  • Use TLS (STARTTLS) encrypt: yes
Office365 / Exchange server
Setup may be (see however note after):
  • Server: smtp.office365.com (Microsoft Office 365, Exchange Server).and smtp-mail.outlook.com
  • User name: Your email account
  • Password: Your password account
  • Port: 587
Note: Outlook and Office365 are the worst platforms we know to manage emails. It is not compliant with most web and emails standard so the setup is often difficult with this platform. Documentation about SMTP credential is also poor. It depends on a lot of parameters saved into your Outlook platform. Ask the parameters to use the SMTP server of your Outlook platform to your Outlook provider. Only your Outlook provider is able to give you this parameters. If you can't contact him, I'm afraid, trying any combination of parameters is the only solution to find the good one with this email platform.
SendGrid
Setup would be:
  • Server: smtp.sendgrid.net
  • User name: Your SendGrid api key
  • Password: Your SendGrid api pass
  • Port: 2525
Outlook
Several smtp logins or servers
If you need to have each user to use a different SMTP login account or a different SMTP server, you might be interested into the module MULTISMTP: https://www.dolistore.com/en/moduliplugin/458-MultiSMTP.html Note that in most cases, even if each user has its own email address and its own mailbox and "Sent" directory, using several SMTP login/servers is not required (see for example the comment for Gmail setup using the "relay" mode).
Actions
Test server availability
This button is to test if you can communicate with the server. This allow you validate the parameter:
  • Hostname or ip address of SMTP/SMTPS sending server
  • Port of SMTP/SMTPS sending server
  • Usage of TLS (SSL)
Test send email
This button is to test what happens when you send an email with simple text content.
Test send email HTML
This button is to test what happens when you send an email with HTML content.
SPAM troubles
If your email is set as SPAM by your EMail reader, you can test to send en email to this service to get more information why your email is set as SPAM: http://www.mail-tester.com/
Emails Tracking
Like most modern ERP and email clients, all emails sent by Dolibarr contains a header line "Reference" with a tracking information to know from which source element the email were sent. This tracking informations will also be present into the emails answer, but only if the reader sent the answer using the "Answer to" feature of its email reader and not by creating a new email from scratch of course. This tracking id can be used by the "Email collector" module that scan your mailbox and can automatically store the answer as en event in your Dolibarr, at the good place (same customer and same quotation for example).
