Module MemCached
Revision as of 12:40, 20 March 2020 by PolyglotBot (talk | contribs) (Adding interlang links (links to translated versions of this page in other languages) triggered by origin English page "Module_MemCached" update.)
Module name Accelerator MemCached
Editor / Editeur NLTechno - http://www.nltechno.com
Last update date / Date mise à jour fiche / Fecha última actualización 2020-03-20
Allows Dolibarr to increase speed by using a cache server MemCached. Dolibarr use this cache to store result of redundant operation like IO used for reading language files. According to platform, speed increase can be between 20% and 40%.
Prerequisites
To install/use this module, you must before:
  • Have a running memcached server and know its address (ex: localhost) and its port (ex: 11211). Process to install such a server is not part of this documentation. See articles found on the Internet for this. Ie:
- See http://rutfin.wordpress.com/2013/05/19/installing-memcache-on-windows-8-for-wamp-server/ for install on Windows
- See https://www.tecmint.com/install-memcached-on-ubuntu/ for install on Ubuntu, ...
- See https://wincent.com/wiki/Installing_memcached_1.4.1_on_Mac_OS_X_10.6_Snow_Leopard for isntall on MacOS 10.6
  • Have functions "memcache" or "memcached" activated into your PHP (Go into Dolibarr menu Home -> System information -> PHP to see if at least one PHP client (memcache or memcached) is available.
Again, if those functions are not available, search article on the Internet to see how to setup your PHP to support memcache ou memcached.
Module setup page:
The tab Server setup
In the server setup page, you must fill the following information:
  • Name of Memcached server: Put a DNS name or IP address of Memcached server.
  • Port or Memcached server: Put here the port of the Memcached server.
Save and that's all. Dolibarr should now use the cache server when it can.
Note: If you add the line
into file htdocs/conf/conf.php, then the 2 tabs to view statistics on cache server are removed. This is usefull for web hosting providers of Dolibarr (SaaS) to avoid users to see information (the cache content) shared by the hosted server.
The tab Server statistics
This tab show you the status of the cache and how much it is used. To have an idea of the efficiency, see the next chapter.
This module is a technical module. As soon as setup is done, Dolibarr use the cache server when it thinks it's necessary. There is no other things to do.
The following screenshot show you a performance comparison, done with BlackFire, with and without the module. As we can see, the gain (59ms faster for a total of 152ms, so 25% faster) is mostly on the step to load the language files (already in cache, 56ms for this step in function Translate::load).
