Module Timesheet
Revision as of 10:56, 10 March 2020 by Eldy (talk | contribs)
<seo metak="timesheet, Dolibarr, interface, project, task, report, approval" />
Warning.png This module is an external module. It is a duplicate of the native feature to enter timesheet available in Module Projects.
Module name timesheet
Editor / Editeur delcroip
Prerequisites / Prérequis projects
Last update date / Date mise à jour fiche / Fecha última actualización 2020-03-10
Note / Nota Latest Module version: 2.0.1
- Timesheet interface for all the user task per week
- Generate report on user and on project per month
- favourties to show only some project/task by a simple click on a start icon next to the task name
- Approval of the timesheets per the N+1
- Approval of the timesheets per project manager
- Generate project invoice from timesheet data
Change logs
2.0.1 Change log from 2.0
* Project approval corrected (for non admin no approval was shown)
* PHP warning removed
* Home timesheet box correted (was not showing the # of timesheet to approve)
2.0 Change log from 1.5.1
* Week on two month are spliced to enable monthly approval
* Chained approval for team & project.
* Create invoice with ad-hoc and already defined service based on time saved.
* Report always shows time in day and hours
* Layout change for the setup page
* Layout change for the favorite handling
* Email are sent to user when a timesheet is rejected by the team leader
* Note on task are shown as info when hoovering over the task line
* Searchbox are available instead of dropdown list (use other core module setup).
* More translation (ES, DE, IT, FR, US , mostly automated)
* Note editing available for each tasks (also in the approval flow)
Change log from 1.5
* Support dolibarr 4.0.1
* Hidden option to join file to timesheets via the setting TIMESHEET_ADD_DOCS
Change log from 1.4.3:
* Timesheet approval by N+1,
* Reminder (email) for to be approved timesheet possible through dolibarr planned tasks
* admin wiew for the Approval (change a approval status outside the normal approval flow)
* Home box with the pending timesheet to be approved
* Blocking some weekdays (e.g week ends)
* Holiday showed in the timesheet
* Holiday time can be included in the timesheet totals
* Typo correction for French.
* Posibility to add a note
* Compatible with dolibarr 3.9.2
Change log from 1.4.1:
* Correction of the Spanish language (thanks to vinclar)
* Possible to deactivate the dolibarr Ajax for the dropdown list for the setup page (in case of issue to add whitelist)
* Keep the whitlistmode after submit / go to date / next / previsous week
Change log from 1.4:
* Bugfix for the tasktime date in the project page
* Link to have the different whitelist behaviour (black list, and none)
* Spanish language (google trad)
* Support the print mode for timesheet & the report
* Show the project open to everyone on the new whitelist page
Change log from 1.3.7:
* layout improvement: timesheet, setup page, reports
* whitelist to show only some project/task
* taslk column customisation
* new task column: company, parent task
* new report option: report all, export friendly layout
* user report available for the N-2, N-3
Change log from 1.3.6:
* compatible avec dolibarr 3.7
* Change log from 1.3.3:
* Works with PHP<=5.3
* Possibility to remove the 0:00
* Color code for already filled tasktime / new tasktime and error
* Bux fixes in the report
* Better date dialog
* N+1 is able to check the user report of his N's
