FAQ Directory Custom external modules
Revision as of 20:34, 18 February 2020 by Eldy (talk | contribs)
For very old version of Dolibarr, you must execute this before being able to install an external module.
Why my module does not appear ?
  • Make sure Dolibarr is already installed and configured on your workstation or development server.
  • In your Dolibarr installation directory, edit the htdocs/conf/conf.php file
  • Find the following lines:
   php
   //$dolibarr_main_url_root_alt ...
   //$dolibarr_main_document_root_alt ...
  • Uncomment these lines (delete the leading //) and assign a sensible value according to your Dolibarr installation
For example :
   * UNIX:
       php
       $dolibarr_main_url_root = 'http://localhost/Dolibarr/htdocs';
       $dolibarr_main_document_root = '/var/www/Dolibarr/htdocs';
       $dolibarr_main_url_root_alt = '/custom';
       $dolibarr_main_document_root_alt = '/var/www/Dolibarr/htdocs/custom';
   * Windows:
       php
       $dolibarr_main_document_root = 'C:/My Web Sites/Dolibarr/htdocs';
       $dolibarr_main_document_root_alt = 'C:/My Web Sites/Dolibarr/htdocs/custom';
You may have to create the htdocs/custom directory first if it doesn't exist yet.
  • Unzip the custom module zip file in the htdocs/custom directory
  • You should now have a htdocs/custom/modulename directory
  • Refresh your browser, Go to "Setup" -> "Modules"
The module displays in one of the sections, you could enable it and then start using it ;)
If the module is under development or experimental
Got to "Setup" -> "Other setup" and set MAIN_FEATURES_LEVEL to 2
For more information about the conf.php file take a look at the conf.php.example file.
