Module EsAEB
Revision as of 13:43, 11 December 2019 by Eldy (talk | contribs)
Module name
Editor / Editeur 2byte.es (www.2byte.es)
Last update date / Date mise à jour fiche / Fecha última actualización 2019-12-11
Create withdrawals files in the formats established by the Spanish AEB. Today generates the file under Rule 19.
What is AEB?
The Spanish Banking Association (AEB) is a professional association comprised of almost all Spanish and foreign banks operating in Spain. Among its tasks is the standardization of operational procedures to be used in banking relationships.
More info(Spanish only)
Module info by official developer: www.2byte.es
Technical info and manuals: www.2byte.es
Acquire the module: www.dolistore.com
Terms of Use, Maintenance and Support: www.2byte.es
