Roadmap and Release 2.2.0 ("Purged version")
Roadmap Dolibarr pour la version 2.2.0
Corrections des retours de la 2.1.0Correction pb avoir client
- Add more statistics on main page.
- Add option to add message on login page.
- Management of categories for third parties.
- Add volume on products properties.
- Support for LDAP authentication.
- Full member synchronisation with LDAP database in fundation module.
- More LDAP fields supported for user synchronization.
- Better logger for install.
- First changes to support UTF8.
- Add a "forget password" feature.
- Setup process can run several migrate files if need to jump several versions to upgrade.
- Support for webcalendar 1.1 in webcalendar module.
- Support for menu in database.
- Better support for using Dolibarr on more WHP.
- Removed some deprecated files and clean code.
- New theme: Auguria
- Removed PHP warnings.
- Some bugs fixes.
- Traduction more complete.
- Better code comments for Doxygen documentation.
- Better support of vcard export format.
- Themes are full CSS compliant.
Features (english version)
- Fix bug reports of 2.1.0
- Reported to 2.3.0
Addition of multi-currencies management, only in informative mode at first (Yannick Warnier) - Better database input filtering (prevent easy attacks by disatisfied employees) (continual effort)
- Reported to 2.3.0
Improvements of invoice-related e-mail sending: configurable default fields, automatical CC to a specified e-mail address, drop-down, title and body language in the contact info (introduce concept of contact language) - Reported to 2.3.0
Improvements in the commercial management features. Introduce dated notes, contacts belonging to more than one company, notion of "referral" (a client refers us to another - to keep track of worthy clients) - Reported to 2.3.0
Manage members language (e-mail sending)
Modules à inclure/exclure pour la release
Tous les modules du CVS peuvent être inclus dans la release 2.2.0 à l'exception des suivants:
- Postnuke
Non stable
- Telephonie
Trop spécifique, présente des failles de sécurité graves
- ClicktoDial
Hack grossier sur un système peu répandu
- Bookmark4u
Peu utile
- Barcode
Non fini
- Editeur
En cours de dev, non requis
- Document
Modèles à inclure/exclure pour la release
Modèle numérotation facture
Aucun modele a exclure.
Themes à inclure/exclure pour la release
Tous les themes sont opérationnels sauf 'rodolphe' qui n'a aucun picto.
Autre
- Le support PostgreSQL n'est pas stable (Manque de testeurs) et ne sera donc pas intégré à la 2.2
- Le support MSSQL n'est pas stable et ne sera donc pas intégré à la 2.2
