Draft:Discourse Implementation and Exploitation
Addresses
- dolibarr-test-fr.traulle.net
- dolibarr-test-org.traulle.net
These DN has been choosen to test the distinct vhosts but are not actually binded to public DNS.
You MUST edit your /etc/hosts local file (or similar) to point these addresses to IP 37.59.159.184
For Windows based machines, you can use https://hostsfileeditor.com/ for that purpose.
Replicated minimal VM for tests
For the implementation to go smooth, the vmprod1 environment has been replicated on a dedicated test VM.
- Linux distro : Ubuntu 16.4.7
- Webserver : Apache2
- RDBMS : Mariadb
- PHP : 5.6
PHP version
PHP version is installed from ppa:ondrej/php.
Apache2 config
Apache2 virtual hosts config dolibarr.fr.conf and dolibarr.org.conf has been copied from vmprod1 (Servername apache directive has just been modified to match names specified in #Addresses).
Enabling proxy and proxy_http modules.
Adding
<Location "/forum">
ProxyPass "http://dolibarr-test-fr.traulle.net:8800/forum"
</Location>
Files
Files from /home/dolibarr/dolibarr.fr and /home/dolibarr/dolibarr.org has been copied to the same location on the test VM (however /home/dolibarr/dolibarr.org/httpdocs/files/stable has not been replicated on the test VM due to the weight/size of all packages).
MySQL/MariaDB Databases
Docker
Installed following the Docker docs : https://docs.docker.com/install/linux/docker-ce/ubuntu/#install-docker-engine---community-1
