Draft:Discourse Implementation and Exploitation
Addresses
- dolibarr-test-fr.traulle.net
- dolibarr-test-org.traulle.net
These DN has been choosen to test the distinct vhosts but are not actually binded to public DNS.
You MUST edit your /etc/hosts
local file (or similar) to point these addresses to IP 37.59.159.184
Replicated minimal VM for tests
For the implementation to go smooth, the vmprod1 environment has been replicated on a dedicated test VM.
- Linux distro : Ubuntu 16.4.7
- Webserver : Apache2
- RDBMS : Mariadb
- PHP : 5.6
PHP version is installed from ppa:ondrej/php
Apache2 virtual hosts config dolibarr.fr.conf
and dolibarr.org.conf
has been copied from vmprod1
(servername has just been modified to match names specified in #Addresses).
Files from /home/dolibarr/dolibarr.fr
and /home/dolibarr/dolibarr.org
has been copied to the same location on the test VM (however /home/dolibarr/dolibarr.org/httpdocs/files/stable
has not been replicated on the test VM due to the weight/size of all packages).
