Module Accounting Simplified
Revision as of 09:15, 7 September 2019 by Egils (talk | contribs) (→‎Journals: limit size)
Accountancy
Numéro/ID du module 10
Doc développeur du module Module Accounting (developer)
This module allows you to set up accounting with a suitable chart of accounts.
Its features are:
  • support for double entry accounting
  • grouping transactions in journals
  • support for exports (which formats?)
Chart of accounts
Dolibarr support multiple countries
  • Africa (Benin, Burkina Faso, Cameroon, Central African Republic, Comoros, Congo (Brazzaville), Congo (Kinshasa), Equatorial Guinea, Ghana, Marocco, Niger, Senegal, Tunisia)
  • Europe (Belgium, Denmark, Luxembourg, France, Germany, Great Britain, Netherlands, Romania, Switzerland, Spain, Sweden (pull request pending fix))
  • South America (Chile)
(see full list)
Default accounts
After setting up your chart of accounts you have to tell Dolibarr to use them.
Journals
Set up your custom journals. Here is an example including a special journal for Upwork "bank" account and an equity insert/take out. Accountancy-journals.png
Use
This module contain a ledger that enable you to manually add transactions. However this is not recommended for most transactions.
Transactions from the standard sell and purchase journals can easily be committed to the ledger after they have been assigned valid accounts.
The module also contains a balance sheet for you to see the total income and expense of you company.
Life cycle / Business rules
Examples of use cases
UCAC01:
Situation
Actions
