Table llx cronjob
Revision as of 16:03, 6 September 2019 by Eldy (talk | contribs) (Created page with "{{ListOfTables}} =Content/Contenu/Contenido= {{flag en}} Contains the global application parameters (parameters for which the value is the same for all users). More informatio...")
En verysmall.png Contains the global application parameters (parameters for which the value is the same for all users). More information on page Constants. Fr verysmall.png Contient le paramétrage global de l'application, c'est-à-dire les paramètres dont la valeur est commune à tous les utilisateurs. Plus d'information sur la page Constantes. Es verysmall.png Contiene los parámetros globales de la aplicación (parámetros cuyo valor es común a todos los usuarios). Mas informacion en la página Constantes.
Structure
Table
rowid int(11) NO PRI auto_increment technical index
name varchar(255) NO UNI key/name of constant
entity int(11) NO UNI 1 multi company id
value text NO value of constant.
type varchar(6) YES NULL type of constant (deprecated)
visible tinyint(4) NO 1 is the constant visible in the page home->setup->other ?
note text YES NULL - tms timestamp NO Current date Date of last modification. See page Field Tms.
Keys
Key Type Fields
PRIMARY PRIMARY rowid
uk_const UNIQUE name,entity
