Module Stripe
Stripe
Numéro/ID du module 50300
Doc développeur du module
This Dolibarr ERP CRM module allows
  • to bind your Dolibarr third parties to Stripe customers
  • to display the list of the Stripe mode of payment in Stripe in Dolibarr
  • to pay, using Strong Customer Authentication (SCA), for orders, invoices, lines of contracts, subscriptions or any free amount, online, using Stripe (https://www.stripe.com). See the note at bottom of this page to use the version "SCA ready" of module
Dolibarr is an official L Color Solid.svg
Once the mandatory identifiers are entered, you can use some URL links, provided by Dolibarr, to make or ask your customers to make online payments. These links are provided as "generic link" on the Stripe configuration page. But you will find them also as "dedicated link" on the page of each invoice, each order, each contract, or each member for the payment of memberships.
This is an exemple of the public interface your customer can use to pay you.
Variants
Stripe offers several modes of operation. The old mode is the use of Stripe's "charge" APIs. As of September 2019, these APIs are deprecated to implement the SCA on online payments and 3D Secure v2 (https://stripe.com/docs/strong-customer-authentication). The v10 is ready for this change. Dolibarr v10 offers 2 other modes of operation:
  • By going to Home - Setup - Other and adding the constant STRIPE_USE_INTENT_WITH_AUTOMATIC_CONFIRMATION to 1, Dolibarr will use the PaymentIntent Stripe APIs according to the workflow "Automatic Confirmation" (https://stripe.com/docs/payments/payment-intents/quickstart) , which is ready for the SCA.
  • By going into Home - Setup - Other and adding the STRIPE_USE_NEW_CHECKOUT constant to 1, Dolibarr will use the CheckOut Stripe APIs according to the "Server Integration" workflow (https://stripe.com/docs/payments/checkout), which is also ready for the SCA.
When using Dolibarr v11, the default mode is when STRIPE_USE_INTENT_WITH_AUTOMATIC_CONFIRMATION = 1 with no need to change or edit any configuration variable. So if you want to use another method, you must force this constant to 0.
