Module Accounting Simplified
Revision as of 20:39, 23 August 2019 by Egils (talk | contribs) (→‎Introduction: features)
Accountancy
Numéro/ID du module 10
Doc développeur du module Module Accounting (developer)
This module allows you to set up accounting with a suitable chart of accounts (COA). Its features are:
  • support for double entry accounting
  • grouping transactions in journals
  • support for exports (which formats?)
  • COAs for the multiple countries
(see full list)
Life cycle / Business rules
Examples of use cases
UCAC01:
Situation
Actions
