Module TwoFactorAuth
| Module name | TwoFactorAuth |
| Editor / Editeur | Régis Houssin (iNodbox) - https://www.inodbox.com/ |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2019-08-17 |
| Note / Nota |
With this module, You can add a Double Factor Authentication (2FA) in Dolibarr. This modules support the protocol TOTP. It does not support U2F.
The module is compatible with 2FA OTP tools like Google Authenticator, Authy, ...
