Module Pivot Reports (Cross Tables for Dolibarr)
Revision as of 16:45, 16 August 2019 by Eldy (talk | contribs)
Module name Module Pivot Reports (Cross Tables for Dolibarr)
Editor / Editeur
Last update date / Date mise à jour fiche / Fecha última actualización 2019-08-16
The Pivot Reports module for Dolibarr allows you to define Data Sources (SQL SELECT queries) and to create Pivot reports by simply dragging and dropping the fields of the selected data source.
It provides as standard 17 predefined data sources and 40+ pre-defined reports covering almost all Dolibarr business objects (Quote, Orders, ...)
It gives you the ability to add as many data sources and reports as you want in a funny way.
You have the choice of 18 possible representations (tabular and graphical), 20+ possible calculation operations (Sum, Average, Median, Variance, ...), export of the calculated data in the TSV format, export graphics in image format.
Main screen
Pivot Reports - Main view with legend
The main screen of the Pivot Reports module allows you to manage Pivot reports, so you can:
  • Select a data source (eg Customer Orders)
  • View reports already defined for this data source
  • Create new reports associated with this data source
  • Edit a report
  • Delete a report
  • Rename a report
  • Filter report data
Documentation: Doc Pivot Reports
Demo site: Pivot Reports demo
DoliStore card : Pivot Reports
