Module PHPSysinfo
Revision as of 16:29, 16 August 2019 by Eldy (talk | contribs) (Eldy moved page Module PHPSysinfo EN to Module PHPSysinfo)
Module name PHPSysInfo
Last update date / Date mise à jour fiche / Fecha última actualización 2019-08-16
Include into menu, an entry PHPSysinfo that show all system information of PHPSysinfo tool (See projet http://phpsysinfo.sf.net)
Click on menu entry "PHPSysinfo" found into menu System tools or Administration tools. System information will be shown on main page.
