Module Pibarcode
Revision as of 16:28, 16 August 2019 by Eldy (talk | contribs) (Eldy moved page Module Pibarcode EN to Module Pibarcode)
Module name PiBarcode
Last update date / Date mise à jour fiche / Fecha última actualización 2019-08-16
Add a new barcode generation engine. This engine use the PHP library Pibarocde (non free).
Go on Module Barcode setup page and choose "Pibarcode" as the engine to build barcode.
To complete
