Module Pibarcode
| Module name | PiBarcode |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2019-08-16 |
| Note / Nota |
Add a new barcode generation engine. This engine use the PHP library Pibarocde (non free).
Go on Module Barcode setup page and choose "Pibarcode" as the engine to build barcode.
To complete
