Module BitTorrent
Revision as of 16:26, 16 August 2019 by Eldy (talk | contribs) (Eldy moved page Module BitTorrent EN to Module BitTorrent)
Module name bittorrent
Last update date / Date mise à jour fiche / Fecha última actualización 2019-08-16
Add into Dolibarr, the capability to be a Bit Torrent tracker. This means you are able to serve files to the world on the Bit Torrent network with no need of external web sites or tools.
To complete
