Module Pivot Reports (Cross Tables for Dolibarr)
Revision as of 17:46, 15 August 2019 by ElkoulaniM (talk | contribs) (Created page with "== Presentation == The Pivot Reports module for Dolibarr allows you to define Data Sources (SQL SELECT queries) and to create Pivot reports by simply dragging and dropping the...")
Presentation
The Pivot Reports module for Dolibarr allows you to define Data Sources (SQL SELECT queries) and to create Pivot reports by simply dragging and dropping the fields of the selected data source.
It provides as standard 17 predefined data sources and 40+ pre-defined reports covering almost all Dolibarr business objects (Quote, Orders, ...)
It gives you the ability to add as many data sources and reports as you want in a funny way.
You have the choice of 18 possible representations (tabular and graphical), 20+ possible calculation operations (Sum, Average, Median, Variance, ...), export of the calculated data in the TSV format, export graphics in image format.
